Originally Posted by 3bears
wow, 2000 to 2001 makes that much difference ? I swapped in a 98 elocker into my 2000 and only thing I had to do was make a harness for the elocker ( mine was a non -elocker) and also switched out all the axel/bearings/brakes from one to the other.
Guess I lucked out
good luck, I learn something every day about these 4runners
I think/hope the biggest difference is the brakes. The 01-02 model years have an electronic master cylinder that doubles as stability and traction control (separate brake lines to each corner) and it sounds like there are some minor mechanical differences in the park brake linkage.
There is also apparently a difference between the axle seals, ABS ring, and bearing retainer, but I'm still unclear if there's actually a MY split or if Toyota redesigned all those components and the 01-02 parts supersede the 96-00 parts.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
