View Single Post
Old 08-09-2019, 05:48 PM
Daluvian Daluvian is offline
Daluvian is on a distinguished road
Also I should mention that if it did misfire just because you don’t have a check engine light doesn’t mean head gasket isn’t bad more then likey it’s a cracked head they do this on start up when it’s cold 4runners with the 3.4 do crack the heads a lot and if it did overheat something also to check would have to do a leak down test when the engine is cold to find out. The best way is to get the piston top dead center apply air pressure and open the radiator you can zip tie a rubber glove to the cap area if it fills with air you have a cracked head or see bubbles in the coolant
Daluvian is offline   Reply With QuoteReply With Quote
