Real Name: Derek
Real Name: Derek
Switch-Pros SP9100 Power Cable
I had an inquiry asking if the power supply cable that comes with the SP9100 kit reaches from the battery to the stud on the Power Module... By a longshot it does, here's a pic:
BTW, as you can see, its not installed. Its not time yet, but when I do, I plan to run it down the side of the fender, fuse box and battery, and there is still plenty of length.
Someone posted on another thread that you need to use the power supply that came with the SP9100 or it voids your warranty... Just like the horizontal mounting of the Power Module - Switch-Pros says that it can void your warranty which is why I came up with this vertical mount....
Questions are good, it educates everyone, please keep them coming...
