Originally Posted by 97BlackAckCL
You also could just tap the turn signals
YouTube
Originally Posted by Phil Frames
Originally Posted by r1verf3nix
And I don't disagree but with Oldred's harness you get the connector that cannot be purchased that matches the OEM TRD PRO mirror 5-pin. Then he has done all the research as to where the (4)four wires land to serve the walk up puddle lights and turn signals within the door.
If you know where to land the puddle lamps power wire, I could probably come up with a writeup myself.
Yes, if you are looking for the grounding points, etc. the OEM wiring diagrams will give it to you. The only reason to go with the harness I am making is if you want a plug and play solution without having to mess with the factory harness. So it can be DIY, or you can go with a harness set when they are released after Labor Day. Either way will get you the desired result.
