View Single Post
Old 08-13-2019, 12:21 PM
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
Sherpa Equipment Company - 4th Gen
Located on the front range of Colorado, we are a couple of adventure-seeking, Toyota loving, videographers. On our travels, we needed a rack that would live up to the workload of our adventure video production. We were traveling with large amounts of equipment and camping gear but had very little place to store it. We found that the rack systems available on the market left us sacrificing either strength or modularity. We set out to combine all of the features we wanted into one rack system. We are now pushing to create new products that are both strong and affordable so you can worry less and explore more.
PRODUCTS
Princeton Rack System
Drawer Systems (Coming Soon)
WHAT SETS US APART
QUALITY MATERIALS
Our rack systems are made with aircraft-grade aluminum and stainless steel hardware, worrying about rust is a thing of the past. While our competitors are using thinner materials, we believe in keeping our side plates thick to prevent issues with bowing. Each rack side plate is cut from 1/4” 6061 to stand up to even the toughest loads.
MOUNTING
Our racks use a rubber spacer to form a seal between our rack and your roof. We believe you shouldn’t have to glob on silicone just to make sure you don’t end up with water in your roof. Mounting our racks requires zero modification to your vehicle.
HANDLES
Gaining access to the equipment on your roof can often be the most frustrating part of using a roof rack or basket. We build handles right into the side of our racks to eliminate the issue and give you quick access to your gear.
ADAPTABLE
Our crossbars are designed to move to accommodate whatever spacing necessary for mounting your equipment. It's never been easier to mount your tents, awnings, and more. Simply loosen a few of bolts and slide away.
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
