View Single Post
Old 08-13-2019, 07:44 PM
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
When you installed the new water pump, did you use a torque wrench and tighten the bolts to spec? Or go by feel?
The large-head outer bolts pass through the timing cover, and seal the coolant passages against the timing cover. I can imagine improper tightening causing the inner timing cover seal to fail and leak coolant into the engine case.
waypoint is offline   Reply With QuoteReply With Quote
