Originally Posted by ChrisJHarney
Buying a low trim truck with the towing power you need seems like a really good idea financially. If you're concerned at all with residual value of a vehicle over time, you can't do much worse than a premium trim 1 ton truck. On the other hand, a well maintained low or mid level truck holds it value much better.
Agreed, the top trims plummet fast, after all, the only difference between the top trim and work trim trucks are all of the electronic gadgets and interior furnishings/appointments. I will add a low option base model truck when the time comes.
