Originally Posted by SherpaEquipmentCo
As nice as cut-outs would be for those that want to run flush-mounted lights on the side, we also want to be able to cater to those that like the clean look of having no cutouts. Though a great feature for nice side lighting to keep it clean, we have had great luck using products from Extreme Led and Baja Designs to get a similar result without the use of cutouts.
This all comes down to keeping our lead times short and providing to the masses.
That reply makes no sense. You have cut outs all over the rack. I don't see the utility in 4 hand holds, 2 or 3 would be more than enough if placed at the right locations. You could easily convert a hand hold to a work light cut out or you could make the hand holds work for either a hand hold or a work light.
