Finally got around to this, I’ve had the WS in the garage for a week or two. Super easy.
This is what came out the first 3 quart run.... not terrible surprisingly at 145k
Then the second 3 quart run
Then the first two quart run, looking much better
And the second 2 quart run. At this point I figured the last 2 quarts to make 12 were unnecessary, but I was in it so I figured why not.
The last bit came out looking like what I was putting in, which is awesome.
Only recommendation is make sure you get the right size fitting for the hose connection. I got a 1/4 inch inner diameter brass fitting and it worked, but barely. I couldn’t find a fitting that was 3/8 outer diameter at Home Depot, they must have been out. I got a few drips at the connection but nothing a towel didn’t soak up.
Can’t stress how easy this was, took less than 2 hours total. Thanks OP!
