As long as the boat launch is paved, your truck in 4lo should pull it out no problem.
My boat and trailer are probably 2500ish lbs and towing it definitely sucks, so I could imagine towing a 4600lb setup would REALLY suck. Something with a 2UZ and bigger brakes would definitely be much better.
Like others have said, if you plan on using it at nearby lakes, you may be ok (I would still do the TBU) but if you plan on towing this thing all over the county/state, I would consider getting something with some more ponies.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
