Originally Posted by progress4m
Looks great! I am not sure if black color of your truck makes the difference, but considering you have 1.75 lift those stock size tires still feels the wheel well really nicely!!
Originally Posted by flyfishin
I agree. The stock size looks perfect with that lift. Great looking rig.
The 265 Wildpeak has 9 inches of tread. This is on 7.5 wheel but I don't think it matters because the tire unmounted is still 8.9". Section width is different and wheel size matters there.
9" is A LOT for a 265. The stock tire is 8.3" wide in the tread area and most 265s are between 8.3 and 8.8 wide.
In fact, there are 275s that are narrower than a 265 Widlpeak and 285s that are barely wider. It all depends on the specific tire.
On the other end, this also makes comparisons vs 255 exaggerated. Whereas a normal 265 would be 0.5" plus minus a little bit wider than a 255, the P265 Wildpeak is more than 1.25" wider than the narrowest 255s!
So, nothing like the 10 mm difference on either end.
