Real Name: Ron
Real Name: Ron
Running the power steering pump without fluid for any length of time will generally destroy it, and it may lock up taking out the serpentine belt, in which case you've got other problems. You might get lucky, but I wouldn't go far, and keep an ear out for a squealing belt when you do drive it.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
