Thread: Mystery Machine
View Single Post
Old 08-18-2019, 05:46 PM
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Originally Posted by jack333 View Post
My engine is toast?? It just hit 100k. That can't be right. Everything else works great.
My take. If you ran it out of oil, some areas suffered from lack of proper lube. It may still run, but you had to have had some serious metal to metal friction.
It may act like mine did, it may run sorta ok driving it for awhile. But you'll see the damage by how much oil it uses now. The pistons/rings/bearings had to take a beating at say 5 quarts low for extended run and RPM.
I got 30K more after this on mine, I was amazed it never seized.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
