Originally Posted by Motory
Yeah, basically what I did was buy a hi lift mount made for a Jeep JK (something like this), stripped the paint, then welded it to the swingout arm. It does wobble a little bit because the metal the mount is made of is a little thin, but I've taken it off road a few times already and havent had any issues. I'll probably fix it down the road by welding on some kind of stabilizing bar.
Also, should note that, if you do this, the hatch barelyyyy clears the hi lift when you open it. You'll have to do a lot of measurements and testing to make sure you're putting the hi lift in the right place on the swingout arm otherwise you might not be able to open your hatch.
Awesome thanks for the info, it looks great.
Those access panels are sweet.
Cheers from SoCal!
