Originally Posted by myarrowsaim
I have lights that have a high and low beam, thus needing a dpdt switch (on-off-on) rather than a standard push (on-off) switch.
I have this switch here, which works great, except it doesn't fit!
Hey myarrowsaim &
HoustonT4R
Why not use an spst
"AOB Switch" and
TWO 12V SPDT relays?? It'll accomplish what you want it to, cost about $10 bucks for a pk of five on ebay (
5Pcs DC 12V Car SPDT Automotive Relay 5 Pin 5 Wires w/Harness Socket 30/40 Amp | eBay ), and very easy to connect right near the switch or under the hood(?)!
So you'll use two relays... just connect both coils; terminals #85 & 86 together (in parallel) NEG to NEG and POS to POS. And you'll have 4 poles; load circuits (2 extras), which you won't need... really simple to do, and the AOB switch will fit perfectly in the dash like a factory switch; even the back lighting will match your other dash switches!
Use
Helux-Prado push button AOBSW800 & 900 series! Search results for: 'Aobsw800' 'Best to you',
rig
