My original idea of mounting a bracket to these studs in red should work. We can probably do all 4 studs though with a CNC'd bracket that looks like the one below. The only problem is the studs need replaced with longer ones, and to replace the studs the backing plates/hubs need pressed off the shaft. Good thing I have a complete axle assembly sitting in my garage to pull parts and measure from. I just ordered the Wilwood mechanical caliper.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
