Originally Posted by Arv
I'll definitely check everything but last time I checked by pushing/pulling on the tires on the top and bottom everything was tight. this is the way to check right?
thanks!
That will in no way tell you if the lower ball joints are in good shape. They support the weight of the truck in tension when the truck is on the ground, and even off the ground, they will be under decent tension due to the bushings, swaybars, etc.
The service manual procedure includes a pry bar and a dial indicator... Less than 0.5mm/0.0020" of play is allowed in the lower ball joint.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
