Originally Posted by Fried Rice
Interesting. I bought a set of the Auxbeams for the low beams on my 2008, had no problems at all and really liked them so I bought two more sets for my high beams and my Mustang. The one of the two bulbs for the Mustang fits more loosely than I’d like (sounds similar to your experience) but the other is nice and tight. I installed the high beams in the 4Runner and neither one worked initially, so I flipped the connectors and both worked, but I had to tape the harnesses together since the latches are now 180 deg apart. That’s sort of lame, but overall I like the Auxbeam product.
You can swap the position of the wires on the bulb plug ends - Just use a small pick or blade to release the small pastic tab that is holding the terminal end in place and the wires will slide right out. Once that is done the locking tabs will line up with the factory harness.
