Originally Posted by Raingler_Nets
Pull out the panel is best and safest. Just made some simple "L" brackets to anchor solid and cut trim panel exactly so it is a tight fit. Yes, the panel is "permanently" modified but no rattles and solid as hell. It's staying there forever just as if it came that way in ours.
The shops will not be cheap on this, probably $500 or up depending on the area just for the labor.
NOTE: I ran high end car audio shops for years so this was a no fear approach for me but your results may vary.
what subwoofer are you using?
