Probably NOT fuel filter -- bad filter would not cause sudden stall with easy restart.
When the engine dies, if electrical accessories stay on and the battery warning light comes on, check for bad engine ground cable or connections.
If everything electrical shuts off along with the engine, check ignition switch and battery connections/cables.
My best guess would be that the techs failed to properly tighten a ground wire or battery cable when replacing your stereo. If it's not that, then check the ignition switch.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
