View Single Post
Old 09-01-2019, 10:59 PM
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Originally Posted by BoomerBob View Post
The 4 banger has so much more room in the engine bay than the V6. I just did a head gasket replacement on an overheated V6 only find out the rings on a couple cylinders were destroyed. Looked fine visually. The new long block should last for many years though.
How is the power difference between the 4 and the 6? Torque difference?
Nice build!
This will be my first 4 cylinder automatic experience with larger than stock tires. The RZ motor is my choice out of the two hands down. The difference in power just does not justify the drawbacks of the V6.
I know a lot of people sing the praises of the 5vz, but I just don't see it, sure it's reliable, but doing even minor repairs is a nightmare since the dohc design makes it a snug fit into the bay, also not a fan of the front accessory drive, timing and oil pump setup. The later 2GR 4.0 is a much more refined design.
As far as power and drivability goes, I've had experience with both motors in lots of platforms, they drive very similarly, the 3RZ in my opinion gets a bad rep solely because of the highway gears they were paired with in most applications, most notably the standard cab 4x4 early Tacomas that got the 3.48 gears. Of course a v6 truck with 4.10s will outrun that.
I'd swap/R&R 5 RZ motors before I touched a 3.4, especially coupled to an auto. Fingers crossed my 270k mile bottom end holds up for at least a few more miles.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
