Originally Posted by ForRun
Finally got it installed, quiet as a mouse while idle, nice tone while crusing and not obnoxious when punched and didn't notice any drone. I was guessing they wouldn't design something for the stock pro that would sound like shit, I gambled and was right. While it doesn't sound like a 60s muscle car I didn't expect it to. Install was clean, quick and fit like a glove.
Someone mentioned they would only buy the tail piece for the side exhaust...It will line up perfectly, however Toyota is discouraging it. new pipe has three bolts, old one has two. You would need to cut and clamp or weld to get just the tail piece.
Someone mentioned the pipe hangs low. With Gibson and others one needs to cut the plastic behind the mud flap so it does not melt it or rub. Easy enough to do, just guessing Toyota put it lower to clear the plastic with the proper clearance.
More smiles per gallon with the runner, I like it!
Added bonus. The tip is welded so the punks won't swipe it!
Nice, cant wait to pick it up and install mine this weekend
