Originally Posted by Trent
I think you should start with unplugging the 12 wire connector, clean the contacts good, reconnect, and then visually inspect for other wiring damage. Inspect the a actuator itself for physical damage. Interesting that the problem showed up after you were on some rough terrain.
The actuator and wiring didn't have any damage, as that was one thing I did check as i slammed down on some rocks. The RCI skids did a good job there. I didn't unplug the 12 wire connector, but I will give that a try, and thank you for the suggestion and for the diagram!
It might be a day or two before I can get under there, we're getting hit by Dorian currently into tomorrow.
2004 toyota 4runner v8 4x4.
Bilstein 5100, Toytec Superflex, toytec/elibach front lift coils, 1 inch toytec body lift. 17x9 Method The Standard wheels, 285/70/17 Cooper AT3's, LC80 Snorkel
