Originally Posted by 2ndhandyotaman
Got one of those as well!
@ paddlenbike
- my A/C belt tensioner was broken, the bolt looked like it broke off a long time ago, no way to get it out of the bracket without cutting it to pieces. The bearing is sealed into the pulley so there's no feasible way to replace just the bearing. The part from Toyota came with the adjuster "stud", pulley and bearing. You have to buy the long adjuster bolt separately. Both parts were right around $40 together.
I do have a new crank pulley bolt on the list, but thanks for the reminder. I'm also considering replacing the bracket that holds the fan as it has a bearing in it as well. I've seen others replace it when doing a timing belt job.
