View Single Post
Old 09-08-2019, 07:04 AM
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
2 cam seals at the front (usually done with a timing-belt change as the cam gears have to be removed). The rear are just 2 caps:
camshaft plugs (2) 11188-62010
that are only done with the valve cover gasket. Here's my parts list for just the Valve Cover side (and quantity/rough pricing). The cam and crank seals came with my timing belt kit via ebay.
throttle body gasket 1 22271-62040 $4.60
Plenum Gasket (2) 2 17176-62040 $9.91
valve cover gasket (2) 2 11213-62020 $24.80
PCV Valve 1 12204-62010 $9.76
PCV grommet 1 90480-18001 $4.40
half-moon plug (4) 4 11183-62010 $6.84
valve cover washers(16) 16 90210-05007 $1.01
camshaft plugs (2) 2 11188-62010 $9.61
sparkplug tubeseals (6) 6 11193-70010 $2.75
FIPG 1 00295-00103 $12.55
Good idea to do sparkplugs too, and wires if you don't know their age. I'm tossing in reman fuel injectors too, just because I really only want to take that whole mess apart once in the next decade.
Brian. is offline   Reply With QuoteReply With Quote
