The fibrous nature of the brake dust indicates to me that the brake shoes were contaminated with brake fluid when the wheel cylinder was leaking. Definitely will cause a grabby/ sticky brake especially when damp out or the brakes are cold. Clean the shoes with brake cleaner spray and sand them a a little. Sometimes I will take a torch and burn the gear oil or brake fluid out of the shoes. (carefully, you don't want to cook them.) Clean the drums out really well also. Make sure your e-brake bell cranks are not seized up as well. If not and cleaning the shoes and drums doesn't fix the problem, replace the shoes.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
