Making some progress. After pulling the engine we removed the wiring and dash, pressure washed the engine bay, then removed everything else on the front end. 27 years of oil and grease had to be cleaned up. Welded up some steel plate for the clutch cable entrance that was cracked and partly missing. It's very solid now. Also removed the rear end and fuel tank to get that all cleaned up. Scraped and pressure washed the underside of the car as well. A prior failed pinion seal had made quite a mess back there.
At this point the engine bay is in primer. Need to finish up the rest of the body work (bumpers, block the hood, address some dings) and get the whole car in primer and blocked. Hoping to have it in paint in the next few weeks before the weather cools down too much.
Once it is painted, the rest is just cleaning up/purchasing parts and re-assembly.
Missing bits of the firewall from PO using the wrong bell housing and clutch fork. Way too much pressure here.
Bought the world's smallest welder and got some work done
Not pretty but solid. The rough areas that you can see are seam sealer.
K-member out
Cleaned, primed and slid back under the car
Engine bay primed
Fuel tank and rear end pressure washed
This was nasty before! Hasn't been this clean since 1992.
Garage buddy, one of many helpers in my house.
Won't be long 'til paint. More to come.
