Originally Posted by 19963.4lsr5
It uses the speed from the ABS computer. I forget which input it is. I went through figuring out which speed input is used when I installed a factory NAV unit and needed the speed input to make the NAV accurate.
More specifically, is uses the signal from the ABS computer that is processed by the gauge cluster and sent to the ECU from there. With more context, we can help you with whatever you are getting at...
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
