View Single Post
Old 09-10-2019, 04:32 PM
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Not sure if these are just bulbs or new lights with relay harness...
Troubleshooting ideas:
Confirm the lights work (connect directly to battery)
Check the relay for function (measure voltage at output and confirm its even switching)
Check for voltage at the switch
Check the switch for function using the continuity function on the meter.
If it's just a bulb, you can connect that directly to a battery to make sure it works. Alternately, put the stock bulb back in and make sure the system as a whole still functioning.
