View Single Post
Old 09-11-2019, 05:29 PM
4by4runr's Avatar
4by4runr 4by4runr is offline
4by4runr is on a distinguished road
4by4runr's Avatar
No heat diagnosis and solution, heat blend door servo actuator
Updated with solution and title change for reference.
OK: Update and solution.
Fixed for $12.95 at u-pull.
Adding procedure for anyone else that may be looking for this solution.
1. Remove glove box
2. Remove 2nd glove box. 4 screws
3. Remove lower cover. Black 1 screw. Disconnect wiring harnesses.
4. Remove black floor vent on the left. It will kinda pop off with some force.
5. Unplug wiring harness from heat mixing servo
6. Unscrew bottom front brass colored screw from mounting bracket.
7. Unscrew bottom rear brass colored screw from mounting bracket.
8. Push/shove/Pry mounting bracket to the right, you will expose 3 more screws that are more easily unscrewed than that 1 remaining mounting bracket screw. Yes you are bending the bracket, SHOULD be fine, it took me 5 minutes at u-pull of bending it back and forth rapidly so maybe 150 bends, to get it to break.
9. Remove these 3 screws. (there is a chance that the servo arms could be blocking 1 screw depending on where it failed. The tools I used to remove these were a 1/4' short socket that will accept a small Phillips bit turning by hand. You could possibly fit a small ratchet in there. If you have giant hands, this part may be tough but still easier than removing the furthest rear screw on the mounting bracket.
10. Remove the servo/housing. So the orientation will be to have it start doing a backflip (counterclockwise rotation looking at the face from the passenger side) while pulling it up. There are 2 kind of legs that will complete it's rotation when those are parallel to the earth. Then wiggle it.. just a little bit...you've got to wiggle it.. ok... a lot. and it should pop free down and out the front.
11. Install new $13.00 servo by reading this list backwards.
__________________________________________________ _______________
Hopefully somebody can point me in the right direction here.
So going over monarch pass it got a little cold and I went to turn the heat on but nada.
I have checked:
Coolant overflow is at normal level.
Both the inlet and outlet of the heater core are hot at the firewall.
The engine is not overheating or underheating.
The fan is operating normal.
The mixing door that opens and closes above the cabin filter is operational.
There is no heat at any setting (vent, defrost, floor)
I don't know what to check next.??
Any thoughts are greatly appreciated
2004 V8 4x4 sport in Galactic Grey • Xreas delete • 248k • BFG KO2 265/70/17 • Custom Arizona sun two tone paint • 2" leveling kit
4by4runr is offline   Reply With QuoteReply With Quote
