Originally Posted by DUK-RNR
What I've found on line is, jack up the front wheels, suck the fluid out of the reservoir, then put fresh fluid in, start the engine turn the steering wheel back and forth, and repeat until the fluid is clear. This takes a long time.
Is there any reason why I can't pull one of the fittings loose from the rack , take the top of the reservoir and let it drain(engine off)
While we're at it doesn't power steering fluid work just as well as Dextron II?
You probably could do that but you will introduce a lot of air into the system, watch Timmy the toolmans video on YouTube he has 2 for flushing the power steering system. I kind of did a mixture of both of his videos, removed the fluid with a turkey baster and small syringe 5-10 times and then removed the reservoir and cleaned the screen.
