Originally Posted by DUK-RNR
What I've found on line is, jack up the front wheels, suck the fluid out of the reservoir, then put fresh fluid in, start the engine turn the steering wheel back and forth, and repeat until the fluid is clear. This takes a long time.
Is there any reason why I can't pull one of the fittings loose from the rack , take the top of the reservoir and let it drain(engine off)
While we're at it doesn't power steering fluid work just as well as Dextron II?
Do not use power steering fluid. Different additives than transmission fluid.
