I had a similar issue last summer. Intermittently wouldn't start with no codes, no starter cranking sound and verified good battery/alternator.
It ended up in my case being a faulty fuse on the starting circuit (would need to look at the engine bay fuse box to be sure, but believe it was the EFI fuse). Fuse pin was loose. Once started the truck would operate normally. New fuse and it was good as new.
