Getting the quirks all worked out. She's running at the perfect temperature no issues there. Transmission was a little lazy the first couple times out but I've finally got it topped up just right and she's shifting really nicely now. The ECU threw a code for the O2 sensor so I went ahead and swapped it out. Now my idle is going down below 1k and she purrs like a kitten.
Still on the mechanical to-do list is a new set of front brakes, they're causing some pulling and wobbling. There's quite a bit of crusty rust built up on the slide pins, along with the rotors not looking hot. Gotta get the rear drums off for a checkup and adjustment too. The passenger CV already puked a bit but no tears yet.
On a very happy side note, I did the math yesterday to confirm my suspicion. The Auto 4X4 3RZ did come with 4.56 gears. At least in my case. It drives great with the 33's very happy. Need to make a trip to the junkyards and hopefully piece together the interior a bit better, and with any luck I'll stumble across a clean black hatch sometime soon.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (
Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (
Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
