390,000 kms and my front bearings are still fine. Had to replace the rears because of the axle seal leak @ 350,000 kms. When bearings start to fail, they make noise which gradually gets worse over time. Even when they make noise there's usually a ton of time left of which you'd have to be severely negligent for the wheels to fall off. Keep in mind that the front bearings are significantly beefier than the rears...there is ALOT of room left for error from the time they start making noise to when they are no longer safe.
