Real Name: Chris
Real Name: Chris
Substitute 1 quart of oil for 1 quart MM oil and use some cheap oil, store brand is fine. It's generally super cheap so great for 500-1000 mile oil changes when doing something like this. Look at Amazon brand oil, it's actually said to be very high quality. Make sure you change the filter every time you drop the oil also. Once you're satisfied the engine is clean, it may not be a bad idea to drop the oil pan and see what's going on in there. Very likely it needs a good cleaning.
