View Single Post
Old 09-17-2019, 03:18 AM
roscoe67 roscoe67 is offline
roscoe67 is on a distinguished road
Originally Posted by BoomerBob View Post
To remove or install the heads on the 3.4L the cams must be removed so the head bolts can be installed and torqued to spec. The the cams go back in. Hopefully the installer installed the service bolt to keep the split gear aligned before removing them. It can be confusing when installing the cams because there are two dots on one cam gear and one dot on the other but if memory serves; there are also two dots on the one dot cam gear. Obviously if both the two dot marks were aligned then it wouldn't run right.
When I pulled the camshafts I installed a service bolt, and it came back with my service bolt still in there. I was careful about aligning the dots on the cam gears (I even put a dot of white paint on the dots to keep track more easily, since they face the firewall).
My concern was about the camshafts being in the correct heads - but they can't go in but one way, correct?
roscoe67 is offline   Reply With QuoteReply With Quote
