Originally Posted by Bad Luck
@ feelingstoned
Where to begin?...
Here's a link to the land cruiser FJ80 spring color coding: LC coil spring Color codes look at post 2
Note: some people switch to OME 861's due to a lot of rear weight (steel bumper with full size tire and other crap) lc 861?
You will need longer shocks to account for the lift height as well as changing your bumpstops. Depending on height you can choose from Tundra 5100's, landcruiser rear shocks, or fj cruiser shocks.
I'm not sure if you can put Tundra front coils on 4runner 5100's. I can't help you there. There is a difference between 4runner and tundra front 5100's. This thread has some measurements between the 2 for comparison: Tundra 6112 Bilstein On 3rd Gen. Info & Install
Ok so the wrap is basically how high it will go? From what i've been reading an 8 wrap is enough and i've been reading a lot of people are using skyjacker for rear, just not sure if I got the correct part #.
