I used a length of heat shrink tubing to cover the connector and factory connectors. I pulled the plastic bulb holder away from the wire/connectors, put heat shrink over the wires, connected the tabs to the plug base shaped LED adapter connection and heated the heat shrink up around the connection. Once it was all secured in place, the plastic bulb base slid back down over the heat shrink and held everything in place. I do not anticipate any problems.
I am also curious what Friggen Idiot didn't like about the signals. I think they're a very clean and worthwhile upgrade for $60. Anything that increases visibility to other traffic is worth my $.
