Originally Posted by fishermunn
i am still on the upper ball joint. any force just moves the ring around the groove. i have no progress trying to pry or knock it off.
the lower ball joint has a larger ring and is more accessible from the top. it may be easier to get off.
there has to be a way to remove the upper ring without resorting to the grinder. i just don't know how.
Maybe obvious answer here but, have you tried the pliers that separate when you squeeze? I have a pair for rebooting CV axles. They are not the little pin ones but just have like flat faces and work really well.
Like these, I bought mine at O Reilly
https://www.kctoolco.com/knipex-45-1...ngs-on-shafts/
EDIT: mine were also nowhere near that price, at the most $20 but I’m pretty sure not even that.
