View Single Post
Old 09-20-2019, 05:11 PM
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
I see a lot of guess work here. START WITH SIMPLE AND FREE THINGS FIRST.
The one thing in common with those alts is the wiring. If the third alt fixed the problem, it was because disconnecting and re-connecting connector rubs off oxidation on the pins.
Toyota components are bullet-proof. Bad wiring usually causes problems. had what looked like a serious problem last week, only to find out it was a bad "S" pin connection. Fixed by cleaning and tightening connector pins.
Originally Posted by Kanoe View Post
Isn't there supposed to be battery voltage fed TO the alternator on one or them to make the alternator work?
... I have read about broken wires right on the connector, maybe a good visual will turn up something.
Yes this^^^
S- wire senses battery voltage. If this is broken, you would get over-voltage
IG - wire "excites" the alternator. If this is broken you will not get charging, low charge if high IG is almost broken (high resistance).
L - is merely fault light signal it will not prevent alternator from doing its job. It should be close to 12V when system is working well. Close to ero when there is a system fault.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
