Originally Posted by Kanoe
I wonder what is up with that. My Ultraguage measures within .1 or .2 of battery voltage.
You could put your DVM on the 12V pin of the OBD2 port to see if it is a voltage drop in your wiring or if it is a misreporting by the device you are using. What are you using on the OBD2 anyhow?
You called it, it's my OBD-II reader. I get a solid 12.5V at the port itself with key ON. Time to try and explain to the wife why I need another car gadget...
On the plus side, the cheapo cig lighter voltage reader read at 12.4V. I'll use that from now on I think.
