View Single Post
Old 09-21-2019, 01:57 PM
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Auxiliary Fuse Block
Daymn! That's lovely work! I wish mine looked that good. I like the vinyl flooring, too! Low-maintenance; No need to vacuum- Just have a little counter brush (that even works on my carpet) and wipe if needed.
Quick thought on auxiliary fuse box.
Auxiliary fuse boxes are typically not switched. A switched one would require a very thick wire to run to the cabin, to a high-current capacity switch (expensive, and maybe hard to find), then back to engine compartment, OR relay with its thinner control wires running to the cabin, to a lighter-duty switch, then back to the relay in the engine compartment. Too much trouble.
I would simply:
1) Determine what circuits and what current load they would have to put on the auxiliary fuse block,
2) Mount it as close as possible to the battery (I have a 4-circuit Blue Sea fuse block but had been too busy to install it).
3) Figure out main wire to carry that total current from battery to the fuse block,
4) Put a fuse or fusible link, inline or mounted as close as possible to the battery on that main wire. (Similar to the fusible link on our 22R-E's).
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
