Here is something to consider if the valves are that far out your most likely going to be inline for a head gasket in another 20 or 30 thousand miles. You could go ahead and just do it now and have the heads redone at a machine shop. they will set valve lash. The other thing you could try to quite the valves is increase your oil weight and see if that helps.
