Originally Posted by The Cold War Kid
Why would the ABS run when I start it up?
The newer ones have a hydro booster that assists you when braking that abs motor runs to precharge the accumulator with pressurized brake fluid in case it needs to apply the brakes for the vehicles trac control or vsc. You can deplete the pressure by stepping on the brake about 20 times til the pedal feels different and then cycle the key to the on position and you will here it come on.
