Originally Posted by AuSeeker
Any 4th Gen without the "dial" is a 2WD only, both the V6s and the V8s 4WD have the "dial" with the V6 you can select 2WD or 4WD, on both the V6 and the V8 you can also select hi and low range.
If my limited understanding is correct, the V8's are AWD all the time? So getting a 4WD model lets me switch between 4Hi and 4Lo, but otherwise it is still technically AWD? What would be the biggest disadvantage of a V8 that wasn't 4WD?
If it comes down to availability would I be worse off with a V6 4WD or a V8 (2WD?) I'm still a little confused about the V8's being AWD or 2WD
I don't want any trouble, but I do want pie
