I have installed and can recommend the Kenwood KSC-SW11. I have mine mounted under the passenger front seat and tied into the front speaker channels. I like the remote tuner for the sub that allows adjustment for the given song and also if you're using different inputs like CD vs Bluetooth vs Aux, etc.
When I was initially testing the sub, I just had it sitting loosely on the carpet, and the response was ok, but I was little disappointed. This sub has the ability to swap polarity 180, and that improved things. But, when I installed it permanently, things got much better.
I notched the carpet and used two 1" oak blocks to elevate it above the carpet and rear floor heat duct. I used 3M vhb tape to lock the blocks to the metal floor, and then screwed the amp brackets to the blocks.
I think it's important, especially on smaller subs, to make a hard connection to the floorboard. Since a lot of a sub's tones are below human hearing, the ability to feel bass in the seat of your pants is better transmitted this way.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
