Originally Posted by gamefreakgc
Unless your 01-02's ABS pump assembly goes bad. They cost more than the 4Runner can be worth new, around $2200. An engine or transmission swap would be cheaper!
Yeah, but they can still be sourced in junkyards for much cheaper too. On the bright side, 01-02 has 4-channel ABS. They don't act up like the earlier 3-channel system. Only solution to those is a full-on ABS pump replacement as well. That part isn't cheap new either. No one notices the issue because it never throws a CEL.
