View Single Post
Old 10-03-2019, 10:59 PM
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Looking to Turn-It-Up a Notch?
Take a look at the 2.5 Bundle #3 - Adjusters Front and Rear...
Part #Gen5-ICON-2.5-Bundle-3 - Click Here
2.5 Coilover, w/Reservoir, w/CDCV (Adjuster) - Part #58747C
The ICON Vehicle Dynamics V.S. Series 2.5” remote reservoir coilover shocks w/ CDCV are an
incredible upgrade for the front end of the 2010-UP 4Runner.
ICON’s Vehicle-specific valving provides a sport tuned feel on and off-road while offering 0-3.5”
of lift height adjustability for use of larger, more aggressive wheel and tire combinations.
The ICON CDC Valve upgrade is included for those desiring an easy way to tune the ride externally
with 10 adjustment settings from soft to hard.
KEY FEATURES:
• Increased wheel travel and ride quality over stock
• Vehicle specific tuned for superior shock damping and control
• External reservoir to attain cooler operating temperatures during extended offroad use
• ICON CDCV equipped for external tunability of your shocks
• Height-adjustable coilovers offer 0-3.5" of lift height
• ICON engineered coil springs
• 6061 Aircraft grade aluminum CNC machined components
• Corrosion resistant CAD plated shock body with 7/8" induction hardened, chrome plated shaft
• FK Rod End bearings for extended longevity and minimal deflection
• 100% Bolt-on - no drilling or welding necessary for installation
• Made in the USA
2.5 Rear Shocks, w/Reservoir, w/CDCV - Part #57810CP
The ICON CDC Valve is an externally adjustable valve that restricts oil flow into the reservoir which
creates 10 levels of compression damping force ranges.
KEY FEATURES:
- ICON's CDC Valve technology allows for 10 levels of high-resolution compression adjustability with the turn of a knob
- ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression
- Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use
- Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range
- One piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road
- 7/8” diameter induction hardened, chrome plated shock shaft
- Polyurethane bushings and forged steel mounting stems for OE factory type fitment
- PTFE lined spherical bearings and application specific mounting hardware
- 6061 aircraft grade aluminum CNC machined components
- CAD plated, precision machined 1026 DOM steel shock body for maximum durability and corrosion resistance
- 100% Rebuildable
- 100% Revalveable
- Made in the U.S.A.
NOTES: ICON V.S. 2.5 Series shocks are sold in pairs
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
