At the risk of using a wiring diagram from 2010 and it being wrong for yours, the only light green wire I see in that circuit is supposed to go to ground in order to actuate the coil for the de-icer relay. Could that be the wire you are reading from? That being said, it doesn't look like it goes to the switch, but rather the A/C amplifier assembly. Again, yours may be different since it's a 2017 so maybe someone can chime in with with an updated wiring diagram.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
